I have tried to create a conduit run schedule multiple times now. I am sure I am missing on little step, then again
I have created a conduit fitting schedule with no issues at all. All fields are filled out correctly, however I can NOT get any information at all to show up in the fields of my conduit run schedule.
Thanks in advance for the help that anyone can provide.
Solved by CoreyDaun. Go to Solution.
The Conduit Run Schedule will only populate with Conduits of the type "Conduits Without Fittings". This Conduit Type indicates that the conduit run will be constructed using continuous segments and bends, rather than adding joint fittings. You should be able to select your Conduit and use the Type Selector to change it to an appropriate "Without Fittings" Type.
To get around this odd limitation the Revit help documentation offers THIS workaround. Or so I thought... it actually doesn't get around it, though it sounded like it did at first...sorry.
