Revit MEP Forum
None of the Fields in my Conduit Run Schedule are Showing
3 REPLIES 3
chadclark
1006 Views, 3 Replies
I have tried to create a conduit run schedule multiple times now. I am sure I am missing on little step, then again Smiley Frustrated
I have created a conduit fitting schedule with no issues at all. All fields are filled out correctly, however I can NOT get any information at all to show up in the fields of my conduit run schedule.
Thanks in advance for the help that anyone can provide.
3 REPLIES 3
CoreyDaun
in reply to: chadclark
The Conduit Run Schedule will only populate with Conduits of the type "Conduits Without Fittings". This Conduit Type indicates that the conduit run will be constructed using continuous segments and bends, rather than adding joint fittings. You should be able to select your Conduit and use the Type Selector to change it to an appropriate "Without Fittings" Type.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
SteveKStafford
in reply to: CoreyDaun
To get around this odd limitation the Revit help documentation offers THIS workaround.  Or so I thought... it actually doesn't get around it, though it sounded like it did at first...sorry.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
in reply to: SteveKStafford
Still not fixed in 2017.
Very strange limitation indeed.
