Revit MEP Forum
Non of the created elements are visible in Floor plan
2 REPLIES 2
jolieame
1268 Views, 2 Replies
Hi;
I am beginner for the Revit MEP. I just want to  draw a conduit in a floor plan which revit mep system has, but it show me this message: non of the  created elements are visible in Floor plan. You may want to check the active view, its parameters and …
What is the problem here? I could not figure out..
But I tried to draw cable tray, it works..
Thanks!
2 REPLIES 2
Firstly I presume you are using the conduit tool and not the piping tool.
Have you checked that the conduit category is turned on i the view you are modelling conduit in?
Have you checked your view ranges are set up correctly?
Have you checked your options bar to make sure that the elevation of the conduits, etc. are within the view range of the view?
Have you checked there are no filters applied to the view which would turn off the conduit?
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
Thank you for your suggestions, julianjameson8403!
