Revit MEP
0 Kudos
Post 11 of 18
Re: No Hub cast iron fittings
01-07-2013 11:45 AM in reply to: BRYANBRAUER1832
BRYANBRAUER1832 wrote:
Yes.  I used the elbow and lookup table from the link which you attached to your previous post.
I just re-downloaded the zip folder I posted, put the look-up table in the correct folder and the .rfa folder in my library. I then opened a new project after closing Revit down, re-added the quarter bend to the routing preferences, and it still shows up the same as before with a "broken leg." What gives!? :smileymad:
Active Contributor
0 Kudos
Post 12 of 18
01-07-2013 01:01 PM in reply to: MikeSavko6811
Have you tried printing it?  Sometimes stuff shows up strangly on my display, maybe an issue with my video card, but plots properly.
0 Kudos
Post 13 of 18
01-07-2013 01:05 PM in reply to: BRYANBRAUER1832
Haha well I'd much prefer having YOUR issue where the fitting shows up properly. Haven't tried printing.
Distinguished Contributor
5 Kudos
Post 14 of 18
01-08-2013 09:03 AM in reply to: MikeSavko6811
Have you tried contacting Charlotte??  There might be a bug that they can fix but havent been told there is something wrong.
http://www.charlottepipe.com/Default.aspx?Page=TechProdSupport
Try any of them and ask if they could forward to the person responsible for creating their Revit content.
60 Kudos
Post 15 of 18
01-08-2013 09:09 AM in reply to: RKLindner
This whole thread is a great lesson on why you should be cautious using manufacturer content. :smileywink:
0 Kudos
Post 16 of 18
01-09-2013 06:24 AM in reply to: RKLindner
Just sent that Brian an email to see what he has to say. Has anyone else tried downloading the link I posted and seeing if their quarter bends draw like mine?
Active Contributor
0 Kudos
Post 17 of 18
01-17-2013 03:37 PM in reply to: MikeSavko6811
Well Mike, I was so encouraged that my Charlotte no hub elbows displaying properly that I decided to take another fling at using no hub fittings.  When I first told ypu that the elbow displayed properly for me, it was when I inserted the elbow in my model and drew pipes from both connections.
So I configured a no hub pipe type with the no hub fittings in the routing preferences.  Low and behold!  When I constructed a 90 degree bend REVIT inserted a no hub elbow with dicontinuos display of piping at one of the connections, just as you described.
So now I am back to modeling with PVC DWV and specifying no hub cast iron.  It is indeed an imperfect world, and REVIT is less perfect than we have reason to expect.
0 Kudos
Post 18 of 18
01-18-2013 05:11 AM in reply to: BRYANBRAUER1832
Ahhhhh...fancy that. Revit is certainly behind when it comes to MEP.
