Revit MEP
MikeSavko6811
Message 11 of 18 (360 Views)
Re: No Hub cast iron fittings
01-07-2013 11:45 AM in reply to: BRYANBRAUER1832
BRYANBRAUER1832 wrote:
Yes.  I used the elbow and lookup table from the link which you attached to your previous post.
I just re-downloaded the zip folder I posted, put the look-up table in the correct folder and the .rfa folder in my library. I then opened a new project after closing Revit down, re-added the quarter bend to the routing preferences, and it still shows up the same as before with a "broken leg." What gives!? :smileymad:
Active Contributor
BRYANBRAUER1832
Message 12 of 18 (351 Views)
01-07-2013 01:01 PM in reply to: MikeSavko6811
Have you tried printing it?  Sometimes stuff shows up strangly on my display, maybe an issue with my video card, but plots properly.
MikeSavko6811
Message 13 of 18 (346 Views)
01-07-2013 01:05 PM in reply to: BRYANBRAUER1832
Haha well I'd much prefer having YOUR issue where the fitting shows up properly. Haven't tried printing.
Distinguished Contributor
RKLindner
Message 14 of 18 (330 Views)
01-08-2013 09:03 AM in reply to: MikeSavko6811
Have you tried contacting Charlotte??  There might be a bug that they can fix but havent been told there is something wrong.
http://www.charlottepipe.com/Default.aspx?Page=TechProdSupport
Try any of them and ask if they could forward to the person responsible for creating their Revit content.
abulla
Message 15 of 18 (325 Views)
01-08-2013 09:09 AM in reply to: RKLindner
This whole thread is a great lesson on why you should be cautious using manufacturer content. :smileywink:
MikeSavko6811
Message 16 of 18 (313 Views)
01-09-2013 06:24 AM in reply to: RKLindner
Just sent that Brian an email to see what he has to say. Has anyone else tried downloading the link I posted and seeing if their quarter bends draw like mine?
Active Contributor
BRYANBRAUER1832
Message 17 of 18 (287 Views)
01-17-2013 03:37 PM in reply to: MikeSavko6811
Well Mike, I was so encouraged that my Charlotte no hub elbows displaying properly that I decided to take another fling at using no hub fittings.  When I first told ypu that the elbow displayed properly for me, it was when I inserted the elbow in my model and drew pipes from both connections.
So I configured a no hub pipe type with the no hub fittings in the routing preferences.  Low and behold!  When I constructed a 90 degree bend REVIT inserted a no hub elbow with dicontinuos display of piping at one of the connections, just as you described.
So now I am back to modeling with PVC DWV and specifying no hub cast iron.  It is indeed an imperfect world, and REVIT is less perfect than we have reason to expect.
MikeSavko6811
Message 18 of 18 (279 Views)
01-18-2013 05:11 AM in reply to: BRYANBRAUER1832
Ahhhhh...fancy that. Revit is certainly behind when it comes to MEP.
