Revit MEP Forum
Need Schedule to Read TOC on Hanger
5 REPLIES 5
kpierce
416 Views, 5 Replies
Help! I have attached the hanger family that I am having issues with. I am needing it to read the Top of Channel (TOC) height from the Reference Level. This reference level changes throughout the project depending on where the hanger is located. I will need the TOC height to change as my hanger changes to accomodate cable tray, conduit and or busway elevation changes.
Right now, the TOC does not read correctly. Can anyone help?
5 REPLIES 5
Chris.Aquino
in reply to: kpierce
To help the community get a better idea of which dimension is incorrect, pleasre reply with a small sample file.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
kpierce
in reply to: Chris.Aquino
Is the attachment of the family not enough information? Please tell me what more information I can provide.
Chris.Aquino
While we were able to see the dimensions, we're not sure what they should be in your specific use case. More information, like what you are seeing vs. what you expect to see would be helpful.
Chris Aquino
@Aquinotecture
kpierce
The dimensions I am looking for vary depending on the top of the channel 1 (TOC) and the known reference level. It is currently reading between 4 ?" and 6" when I look at my schedule. The dimensions should be reading between 5' and 12'. I need the dimension for each hanger (which varies depending on where the hanger is placed) from TOC 1 to Reference Level. Does this clarify anything? Thank you for your assistance.
Chris.Aquino
Thank you for the update.
What is the reference plane? Is it the floor? The ceiling?
A sample project file with a hanger and schedule would better illustrate what you are seeing vs. what you expect to see.
Chris Aquino
@Aquinotecture
Rail Community
