I would like to know if it is possible create the Material takeoff of a wall showing the various layers of which it is composed.
I want to say: I have the wall "Exterior1" which consists of layers A, B, and C. Can I see the thickness, area, etc of the various layers individually and of the entire wall?
I have not found answers in previous posts I hope someone can help me.
Thanks so much.
Best regards.
Solved by danielkazado. Go to Solution.
I have another problem out of this topic.When I would size the pipes I do not get the "duct / pipe sizing" button.
For the ducts instead is present when I click on a duct.Why?
I just installed the patch for revit in Italian. This problem is only present in Italian versions of Revit. If I open Revit in English I do not have this problem.
How can I do to fix this?
Thanks.
To take the quantity of the wall layers you have to select New Material Takeoff from the Schedules/Quantities. Than you may have a takeoff like the snaphot attached. Hope this is what you are looking for.
