Revit MEP
CADastrophe
Message 11 of 17 (150 Views)
Re: Multiple filters and Clearances
10-31-2012 08:37 AM in reply to: armando
Hi armondo,
Welcome to the Autodesk forums!
The technique you've describe here is a good one, but the View Filter's color overrides WILL still hit the Detail (or Symbolic) Lines within the Family, not just the model elements.
Active Member
armando
Message 12 of 17 (144 Views)
10-31-2012 09:37 AM in reply to: CADastrophe
I do this all the time. Are you sure you used Symbolic/Detail Lines inside of the family to represent the clearance? I attached a pic of one of my vav's colored by filter and still showing my dashed red line to symbolize clearance. Let me know if you are doing the same steps, or upload a simple family that is not working as I have described and I'll take a look at it.
CADastrophe
Message 13 of 17 (137 Views)
10-31-2012 10:09 AM in reply to: armando
Attached is a sample project with a Mechanical Equipment family (including Symbolic Lines), and multiple graphical situations. Revit MEP 2013.
Active Member
armando
Message 14 of 17 (127 Views)
10-31-2012 10:58 AM in reply to: CADastrophe
I just did it here from your own file. Is this not what the Thread Opener desired? Perhaps I'm confused as to what he wanted to accomplish. Let me know if I shoudl also upload the .rvt.
CADastrophe
Message 15 of 17 (120 Views)
10-31-2012 11:06 AM in reply to: armando
OK, I see. So you set the View Filter to override the Projection/Surface Pattern, right? Based upon the OP's attached image early in this thread, he's aiming to change the Mechanical Equipment's Lines to brown, whist keeping the Lines of the clearance zone red.
jonathanroy8675
Message 16 of 17 (118 Views)
10-31-2012 11:08 AM in reply to: CADastrophe
Can you put a snapshot of your filters? I have the impression that you don't overide the line type.
Here's mine.
Active Member
armando
Message 17 of 17 (117 Views)
10-31-2012 11:09 AM in reply to: CADastrophe
Yes I should have been more clear, the only setting I touched on the view filter is the Projection/Surface Pattern Overrride. And thanks for welcoming me to the forum, been a long-time lurker.
