Solved by CoreyDaun. Go to Solution.
The "Length" System Parameter is not accessible in Multi-Category Schedules, so that "Length" Parameter you see is a Shared Parameter as you suspected. Multi-Category Schedules are extremely limited, and are only able to access Shared Parameters and the System Parameters that are commonly available amongst all Categories of Elements.
