Revit MEP Forum
Moving conduits to a new reference level (Revit MEP 2013)
1 REPLY 1
efranki
820 Views, 1 Reply
I drew several conduit runs on one reference level, a new level was added and I need my conduits to be referenced to the new level.
When I select an entire run, I no longer have the option to change the reference level (I suppose because there are straight pieces as well as fittings in the run?).  When I select individual pieces of the run, some will allow me to change the ref level but others give me the error message: The conduit has been modified to be in the opposite direction or insufficient space to create the required fittings.
How can I get everything to the new reference level?
1 REPLY 1
lanl
in reply to: efranki
Hi efranki,
You can try the steps below:
1. Select the conduits and fttings on level 1
2. Use Ctrl+X to cut the seleted items
3. Go to Modify tab- -Paste, click Aligned to Selected Level, in Select Levels dialog, select Level 2. See attachment "aligned to level.JPG".
Then all te condits and fittings will move to level 2 and their reference level will also change to level 2.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
