Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Moving a project
1 REPLY 1
lroeber
207 Views, 1 Reply
Moving a project
i just realized that when that this project got set up  that the arch linked file got moved, now we are two weeks away from issuing CD's, how do you go about moving our file and not the arch linked file?
thanks!!
1 REPLY 1
CoreyDaun
in reply to: lroeber
So the Link was moved and the project nearly completed in the wrong location? I take it the architect informed you? If you go to Manage tab » Coordinates ▼ Acquire Coordinates, and then the Architect inserts your Link using the Positioning: Auto - By Shared Coordinates, then everything should work.
If you were to move your model, it would wreak havoc with all of your sheets and annotations.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
