Revit MEP Forum
Move Model(s) from one Revit Server to another.
1 REPLY 1
chiefbraincloud
989 Views, 1 Reply
We have recently started using Revit Server here, and were attempting to move a model from one Revit Server to another.  We have one in our Denver office, and another in our Cheyenne office.
We (the boss and I) were having some difficulty, so we looked in the help and found some information that indicates you just select the files in one tree and cut or copy them, then select the location in the other tree and paste them, but the way my boss has it set up, he does not have both server tree's visible on the same management page.
So I guess the real question is, how does he get the Revit Server Management page set up to view both Revit Servers from the same page?  I'm sure after that the move will be easy.
1 REPLY 1
Well, since no one else has posted anything... we figured it out.
The Revit servers were both added to the proper .ini file for all the local machines, but the .ini file on the revit server instalation did not have the other revit server added, once that was done, we were able to browse both revit server "trees" from the same admin page.
