Revit MEP Forum
Model text question 2
1 REPLY 1
revitworkbench
285 Views, 1 Reply
Can you associate model text to a referance plane or something similar so that it moves and assocates itself to the new size properly?
1 REPLY 1
CoreyDaun
in reply to: revitworkbench
You can constrain the boundary edges or the center axis to a Reference Plane to control the location of the element.
You can control the depth of the extrusion by linking the Depth Parameter (under Properties) to a Length Parameter in the Family..
You can control the font size by going to the element's Type Properties and linking the Text Size parameter to a Length Parameter in the Family.
NOTE: Model Text can behave quite erratically when it is rotated, or hosted to a face that rotates. It will go as far as disobeying constraints and floating off the host face. This issue was touched upon in >this< thread, where I noted that Grouping the Model Text will encourage it to adhere to dimensions better.
