Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Missing objects
1 REPLY 1
paul_sommer
204 Views, 1 Reply
Missing objects
We have this consultant's model linked in our model. Consultant model does not have worksets, phases or design options.
It's all new work. Showing communications and data devices. Mostly 3 families used.
When we receive updates. We clean & purge the new model. We update links by "Manage->Manage Links->Reload From".
Some of the devices won't show. But if I "remove" the link then linked it, all the devices shows.
Any ideas? This is the first time this has happen to us. We are using Revit MEP 2013 (sp3).
1 REPLY 1
CoreyDaun
in reply to: paul_sommer
It sounds like those elements are being hidden by some other means. Under V/G, is the link set to "By Host View"? Also, if you create a new View with no Template, do those devices show?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
