Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Mirror ELEC Model
4 REPLIES 4
GHASEM_ARIYANI
312 Views, 4 Replies
Mirror ELEC Model
Hi
If the model is symmetric,Is it possible to mirror shaped like
Wiring - plug and ... There?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 REPLIES 4
abulla
in reply to: GHASEM_ARIYANI
You can, but the mirrored elements will become orphaned. Orphaned elements lose their association with a host, so they won't move if the wall moves.
GHASEM_ARIYANI
in reply to: abulla
hi
Thanks for your answer.
This is my problem.
Is there a way to fix this problem?
Because so much time is wasted for a series of repetitive work.
CoreyDaun
If you happen to have a project in which the Architectural elements exist in the same model as the electrical devices, then I've found a method employing the "Mirror Project" command. While this same method can be followed while using an Architectural Link, the elements' hosting cannot be preserved, and they will become unassociated. I will explain this method further, in you're at all interested.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
hi
But File architecture The link is the MEP.
