Revit MEP
thombrady
Message 1 of 3 (177 Views)
MEP Roof Plan
177 Views, 2 Replies
02-18-2014 05:20 AM
I want to show the HVAC Roof Equipment & I have low roofs so I have to adjust the View Range down. I figured if I had the roof plan & kept the roof box checked the only thing I would see below is roofing & anything above it. Unfortunately all the interior walls are showing up also. I know you are going to say shut off the walls, the problem is that the exterior walls also shut off & i am left with an empty shell. I have adjusted underlays, went from Plan to RCP & am running out of ideas. Again the issue is I want to look from above & see all the roofs & Equipment on those roofs & nothing else. thanks in advance
Have you tried creating a Plan Region for the lower roof areas?
CADastrophe
Message 2 of 3 (153 Views)
Re: MEP Roof Plan
02-18-2014 09:44 AM in reply to: thombrady
thombrady
Message 3 of 3 (145 Views)
Re: MEP Roof Plan
02-18-2014 10:29 AM in reply to: thombrady
Thank you, I used that before in 2012 & it did not wotk correctly or I was doing it wrong but that worked like a charm this time.
