Revit MEP
Member
DaraWC
Message 1 of 2 (559 Views)
MEP pipe elevation height problem
559 Views, 1 Replies
08-30-2013 12:18 PM
Hey so I was wondering how do I get the bottom height of the pipe to be correct? For example, when I put in a 8" diameter pipe at an offset of 8.63' (I have set the justification to bottom) I measure the bottom of the pipe and it will show as 8.262'
So my question is, how do I make the pipe specify the correct height that I want from the bottom of pipe to the grade level?
DaraWC wrote:
"Hey so I was wondering how do I get the bottom height of the pipe to be correct? For example, when I put in a 8" diameter pipe at an offset of 8.63' (I have set the justification to bottom) I measure the bottom of the pipe and it will show as 8.262' "
The Justification of the Pipe or Duct does not dictate it's placement - it's more for aligning different sizes of Pipe across Transition Fittings as depicted in the image below.
DaraWC wrote:
"So my question is, how do I make the pipe specify the correct height that I want from the bottom of pipe to the grade level?"
I think the way to accomplish this is to create a dimensional constraint between the bottom of the Pipe (that's already drawn) and the grade level. That will keep the bottom of the Pipe at that exact elevation should the Pipe's size change. There's no real great way to do this.
CADastrophe
Message 2 of 2 (551 Views)
Re: MEP pipe elevation height problem
08-30-2013 12:50 PM in reply to: DaraWC
