Revit MEP
Revit MEP
999 Kudos
Post 11 of 17
Re: MEP light fixture masks linked ceiling grid
12-11-2013 06:06 AM in reply to: dtiemeyer
This can be solved by hosting the nested Detail Item Family to the face of the Extrusion instead of to the Ref. Level. First, adjust the extrusion so that the bottom face of the fixture extends beyond the host face. In the Ref. Level View, select the Detail Item Family and with it still selected, navigate to a 3D View. Select "Edit Work Plane" from the Ribbon, choose "Pick a Plane", Click "OK", and then select the appropriate Face of the Extrusion.
8 Kudos
Post 12 of 17
12-11-2013 10:50 AM in reply to: CADastrophe
You're my hero.
Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
Active Member
0 Kudos
Post 13 of 17
05-21-2014 04:56 AM in reply to: dtiemeyer
I'm having the same issue with ceiling grids. Can you post your fixture that eliminates this issue? Thanks!
Active Member
0 Kudos
Post 14 of 17
05-21-2014 05:04 AM in reply to: CADastrophe
Can you post a sample of the fixture mentioned? I'm having the same issue with ceiling grids. Thanks!
999 Kudos
Post 15 of 17
05-22-2014 05:42 AM in reply to: wilco4
Sorry for the delay; here is an example family in Revit 2012 format using the default Revit recessed light fixture Family.
Active Member
0 Kudos
Post 16 of 17
05-22-2014 07:17 AM in reply to: CADastrophe
Thanks!
New Member
0 Kudos
Post 17 of 17
12-02-2014 05:42 AM in reply to: dtiemeyer
Good question and great solution...this helped me a lot!
