We have an issue regarding exporting mep fittings. We have created the model in Revit 2014 version and we export the model into AutoCAD file and some fittings were not in the specific location as per Revit file. So please suggest.
Thanks in advance!
Solved by CoreyDaun. Go to Solution.
I believe that this issue has come up in these forums before, but I do not recall a solution every surfacing. I would suggest searching this board for related threads and, if there is no solution to be had, open a Support Case with Autodesk Support.
I have the same problem, Is there any way to export plan with exploded fittings? This problem continue until 2010. I use revit 2015 update release 3 and no fix. Autodesk should fix that problem.
Dear Sir,
can you please help me regarding floating fittings during exporting from revit to dwg? I could not able to find any information in this forum. Thanks in advance.
