Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
MEP Family and Section Cuts
4 REPLIES 4
LisaDrago
1319 Views, 4 Replies
Okay -I have a family. It has several families put together to create the family.
WHen I do a section cut in the family editor it works perfectly.
When I bring it into a project - it no  longer works. In the section cut it looks like I am looking at the outside of the family and not actually cutting it.
Images attached
I am obviously missing something - but I can't figure it out.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
4 REPLIES 4
CoreyDaun
in reply to: LisaDrago
Elements of the MEP Categories, such as Mechanical Equipment, will not be cut by a Section View. In order for that to show properly, try either changing it to or embedding it into a Generic Model family.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
LisaDrago
That is exactly it!
Thank you - I knew I was missing something but could not remember what it was.
Thanks again.
LD
jseck
From the Revit wiki page...
Non-cuttable family categories....
  • Balusters
  • Detail Items
  • Electrical Equipment
  • Electrical Fixtures
  • Entourage
  • Furniture
  • Furniture Systems
  • Lighting Fixtures
  • Mechanical Equipment
  • Parking
  • Planting
  • Plumbing Fixtures
  • Specialty Equipment
Cuttable Family categories...
  • Casework
  • Ceilings
  • Columns
  • Curtain Wall Panels
  • Doors
  • Floors
  • Generic Models
  • Roofs
  • Site
  • Structural Columns
  • Structural Foundations
  • Structural Framing
  • Topography
  • Walls
  • Windows
Jason Seck
BIM Specialist
Henderson Engineers, Inc.
Sandleaz
in reply to: jseck
I would not go the route of generic model because other people might have generic models and if they only want to see generic models and not your mechanical equipment (categorized as generic model), they'd have to turn it off in custom link view properties under your link (or create a filter for it).  Same thing with you if you want all generic models turned off but want that mechanical equipment shown.
If you want a section shown, just make a 3D view and adjust the box.
