Solved by CoreyDaun. Go to Solution.
Does anyone know how to change this parameter? See attached..
michaelmead wrote:"Does anyone know how to change this parameter? See attached.."
I think that you first have to go to Mechanical Settings » Pipe Settings » Segments and Sizes and see if the correct Segment type is there. Create a new one and define the Material if need be. Then, go to the Pipe Type's Properties and go into Routing Preferences via the "Edit..." button. Here, you can define a new Pipe Segment to be available with this Pipe Type, and thus, control the Material.
Well I that seemed to be working right up till the point that I remembered that the routing preferences will only take affect on new pipe drawn. What about the thousands of pipe that are already drawn? Is there no way to change there material?
Can you select a segment of Pipe, right-click, click Select All Instances, and then redefine the Pipe Segment parameter for all of the elements belonging to that Pipe Type at once?
Yeah, thanks. Interestingly the pipe segement parameter was blank when I tried that, and appeared to me that this ment that more than one pipe segment was select which didnt make any sense. But there was a hidden drop down menu with the pipe type that I just created (and ONLY the pipe type that i just created) when I selected this, all of them updated. But for anyone else who might read this, I had to duplicate both the material and schedule type and change their names so that it would accept it. But in the data base, although the default material and schedule type appeared to be loaded and functioning, it was not and only after duplicating it, did it work properly.
