Ok, so I dont think Ive had this problem since grad school, so Im a little fuzzy on the details of how I once got it to work. But I have a family with a nested family which has materials associated to it (which are colored). everything looks fine in the both the nested family and once the nested family is loaded into its parent family. But when I load it into the project, I lose the colors of the associated materials (everything turns black)> if I remember correctly, I think it had something to do with phase filters, but I went in there and poked around for a minute, but didnt see any obvious culprits. What am I missing? I feel like it is something stupid but please help anyways! Thanks!
How did you go about changing the material/color? If you change the settings of a Material that is already defined in a Project, a loaded Family will adopt the Material definition that already exists within the Project in lieu of using its own definition.
I chose the nylon material, duplicated it, renamed it, then changed its render appearance, surface pattern and cut pattern to what I wanted...
To start - I've done little with the Material Browser, but I have found that if you 'duplicate' a Material, it retains an association with the original Material. Try using 'Create New Material' instead. But, do note what I said in my first reply. If you load this Family into another Family, that Material will be imported as well. This will only apply the first time, so if you have to change that Material in the Nested Family, reloading it will not replace that Material definition in the Host Family.
I don't believe there is much you can do from the Revit side. However, you should be able to define a color in the AutoCAD file. Attached is an example AutoCAD 2012 .dwg file with three colored cubes which retain their color once loaded into a Revit Family.
