Revit MEP
Valued Mentor
IMCornish
Message 1 of 2 (831 Views)
Manholes/Inspection Chambers
831 Views, 1 Replies
10-26-2012 04:53 AM
Being an Architect with Autodesk's 'Building Design Suite 2013' I am able to deviate from Revit Architecture to Revit MEP for the purpose of doing some simple sanitary and hot and cold water supply layouts for domestic projects.  Now, don't laugh, but it took me about 3 days to work out how to do a basic pipework layout being confused by pipe segments, pipe types and pipe systems, however can someone tell me where I can find some basic fittings such as Inspection chambers (Manholes) and waste traps (P & S)for sinks etc?  Do they exist in the OTB software (I can't find them) or do I have to create my own families?  If the later is the case can someone tell me which template I should use?
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Product Support
Chris.Aquino
Message 2 of 2 (745 Views)
Re: Manholes/Inspection Chambers
11-04-2012 08:14 AM in reply to: IMCornish
I've seen traps available for download in few places online. If you haven't already, I would try Seek.autodesk.com, revitcity, or AUGI.
I don't think I've seen manholes/inspection chambers though. I would check some manufacturer's websites, or if you have a cut sheet for one, you could build it using a generic model template.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
