I'm working on a project where I have to merge several files into one .dwg file for our client. I have to take models that are designed in revit and autocad. I'm noticing when I convert the .rvt files to .dwg, the newly created .dwg files don't have all of the same properties that were inputted into the original .rvt file.
Mainly I need the information in the (Identity Data) to show up in the properties in the converted .dwg file.
Is this a export setting issue or is it even possible? Thanks.
That's what I thought. Yeah, we talked about converting it to dxf but that wouldn't work with what we are trying to do. Thanks for the confirmation.
Do you know if you can just create a Layer modifier when converting to .dwg to just pull the identity information. Such as just a Equipment_Tag?
