Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Looking for a computer that will run Revit
1 REPLY 1
freebrd1230
351 Views, 1 Reply
I am trying to upgrade my computer to run Revit, AutoCad MEP, PD3D and Navis, all of these are 2014 and we will be upgrading to 2015 when it comes out, without spending a boat load of money.
I want something that will last a few years without an upgrade either. We bought a Dell Precision T5600,MT,635W
But when I try to open Revit it takes a very long time and boggs down once it is open.
Do you recomend something that will will. I am tied of the wait time while saving and refreshing Navis.
Thank you
Chris
1 REPLY 1
Lance.Coffey
in reply to: freebrd1230
The System Requirements page shows Minimum, Value, and Performance recommendations for hardware to use with Revit.
If you compare the Minimum to the Performance recommendations, we can see what areas are going to affect performance:
  • RAM (4-16GBs)
  • Graphics card (in the minimum configuration a Display adapter capable of 24-bit color is listed, but in the performance recommendation, this is not listed).
  • Although not visibly different, both configurations recommend the "Highest affordable CPU speed rating." There is a note "Revit software products will use multiple cores for many tasks," but this also means that there are tasks for which Revit only uses a single CPU core. This would be a reason to ensure that each core is as fast as you can afford. The Slow Performance help topic has more information on multi-threaded commands within Revit.
From these three points we can see that RAM, Graphics Card, and CPU are important components to Revit performance. Another point which is not mentioned is the speed of the hard drive. When Revit opens a project, it is expanded into the temporary folder, and this involves a fair amount of hard drive read/writes. A solid state hard drive will noticeably improve performance when opening projects (in Revit as well as other programs).
Looking online, there are many threads (with more information) on this topic, such as the following:
http://cad-vs-bim.blogspot.com/2013/04/whats-best-computer-to-buy-for-revit.html
http://www.revitforum.org/hardware-infrastructure/7693-help-building-new-computer-revit-use.html
Lance Coffey
Technical Support Specialist
