Hey Raf -
So do you want the raduis to be 12" no matter what the size is? In most
cases (at least the OOTB) content is configured to adjust the raduis
depending on the size of the fitting, and is generally some multiplier of
the "pipe size". It should be fairly easy to describe how to modify one of
the "standard" fittings to become a "long radius" fitting, but I want to
make sure that I understand your problem before I tell you how to do it
incorrectly.
If you want to experiment a bit, you might look at the Rectangular Duct
Radius Elbow, which supports multiple radii, and includes linining and
insulation.
jason
wrote in message news:5246593@discussion.autodesk.com...
I am looking for a pipe elbow with a 12" radius. If it could have
insulation capability in it like the ones that come with the package that
would be great.
-Raf
