Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Locating objects from details lines
1 REPLY 1
Pabber
214 Views, 1 Reply
What role do detail lines play in modifying the location of pipe and/or equipment in Revit MEP 2013? I noticed that if I place a detail line near a section of pipe and then click on the pipe, a dimension line from the pipe to the detail line appears.
Thanks.
1 REPLY 1
Chris.Aquino
in reply to: Pabber
When you select an element, shows the temporary dimensions to the nearest element. If you want Revit to use a different element, you can pull the witness line of the dimension to another element, and Revit should remember it, and use that element in the future.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
