Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Linked Room Tags
2 REPLIES 2
spm5
304 Views, 2 Replies
Linked Room Tags
I have an architectural model (with rooms placed and tagged) (revit 2012).
I link this model into my project, but I can not tag the rooms.
When I turn on room fill nothing shows up.
Any idea what the issue may be?
2 REPLIES 2
CoreyDaun
in reply to: spm5
Two possibilities:
1. The Rooms Category is turned off in V/G Overrides. Also check to make sure the Link's V/G's are not overridden under the Links tab.
2. The Cut Plane, under View Range, may be set to 0' - 0". If the Cut Plan does not cut through a Room, that Room will not be visible.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€
āž|āž Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
spm5
in reply to: CoreyDaun
It was a stupid mistake. The phases were not mapped properly.
