Can you circuit to a panelboard if it is in a linked model?
Solved by CoreyDaun. Go to Solution.
Hi Michelle, welcome to the Discussion Groups!
Unfortunately, no. You cannot circuit or otherwise connect systems with elements in a linked model. This also means that you cannot circuit elements (i.e. motors in a separate mechanical model) that reside in a linked model to a panel in the current model.
