Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
linked in levels
2 REPLIES 2
212 Views, 2 Replies
linked in levels
Hi .people
I have made a architectural model containing 3 levels at present GF, FF  & SF.
i then opened up a mechanical template and linked in the architectural model. i expected the levels within the mechanical template to match the levels of the linked architectural model ie:
HVAC - GF
HVAC - FF
HVAC - SF
But the levels within the mechanical template simple stay as they were.
Should this happen or have i just assumed a feature that is not available.Smiley Indifferent
Do i need to alter the mechanical template each time to suit the linked in model.?
still only a novice so any help is very much appreciated
Tags (2)
2 REPLIES 2
CoreyDaun
Levels should not be a part of your Template, and there should not be any in there. The standard practice is to Copy/Monitor the Levels from the Architectural Link (using an Elevation View). This will copy all of the selected Levels into your model and furthermore, using Coordination Review, you will be alerted to any changes that the Architect makes to these Levels. If you need any more info, don't hesitate to ask!
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
thanks alot for your reply, ill try this out, sure ill be back if i get stuck.Smiley Happy
cheers
