I have edited a light fixture family showing the correct voltage and wattage, however it is not letting me create a circuit for the fixture it still is showing 0 voltage and 0va even though the properties is showing it correctly.
Solved by CoreyDaun. Go to Solution.
It sounds like the Parameters of the Family are not linked to the Electrical Connector. If this is not the case, please attach your Family file here.
