Revit MEP Forum
Light Fixture family not showing voltage and wattage
2 REPLIES 2
cesslinger
606 Views, 2 Replies
I have edited a light fixture family showing the correct voltage and wattage, however it is not letting me create a circuit for the fixture it still is showing 0 voltage and 0va even though the properties is showing it correctly.
2 REPLIES 2
CoreyDaun
in reply to: cesslinger
It sounds like the Parameters of the Family are not linked to the Electrical Connector. If this is not the case, please attach your Family file here.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
cesslinger
Thanks! That was it!
