Revit MEP
Active Member
0 Kudos
Post 1 of 5
Levels in Revit
354 Views, 4 Replies
11-16-2013 06:29 AM
Hello
i have a question about adding levels in Revit MEP
i open Mechanical template and when i add levels it only shows in Mechanical Discipline and i can only create floor plan view in Mechanical Discipline
when i open Plumbing elevations it shows the levels but i can't create a floor plane view for the new levels in Plumbing Discipline
i only can do it if i uncheck the ( do not duplicate exiting views ) box
how i can make floor plan view for the new levels in Plumbing Discipline without duplicating the view ???
or i should dublicting the view and change the discpline from properties ???
Distinguished Mentor
185 Kudos
Post 2 of 5
Re: Levels in Revit
11-16-2013 07:43 AM in reply to: Ihab-b
That is what I would do. Duplicate your new view and change its properties (and assign new viewtemplate if needed).
Active Member
0 Kudos
Post 3 of 5
Re: Levels in Revit
11-16-2013 11:33 AM in reply to: EnlInt
is there anything i can do to make Revit create floor plan view for both Mechanical and plumbing discipline ???
185 Kudos
Post 4 of 5
Re: Levels in Revit
11-16-2013 11:58 AM in reply to: Ihab-b
Do not think so. You would have to resort to programming, using the Revit API. However your best option would be to use project templates. Take one time to prepare a good template with (if needed) many levels and many views and you can reuse it in future projects.
Active Member
0 Kudos
Post 5 of 5
Re: Levels in Revit
11-17-2013 01:54 AM in reply to: EnlInt
making a template is the best option
thank you
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
