Revit MEP
Revit MEP
mrkhokhary2k
Message 1 of 6 (916 Views)
Level Wise Schedule of Duct and duct Fittings
916 Views, 5 Replies
04-25-2012 10:13 PM
Hi All.
I have a Revit MEP Model upto 10 Levels.
When ever i go to Schedule and Extract the data, then it show whole of the building fittings and duct sizes.
But I need Level Wise Data.
(i.e Duct Fittings Schedule Level B to Level 9)
Please explain me how to extract/reproduce the
Schedule of Ducts and Ducts Fittings.
Please Help me in the above noted Issue.
Regards.
Distinguished Mentor
asommer
Message 2 of 6 (896 Views)
Re: Level Wise Schedule of Duct and duct Fittings
04-26-2012 08:42 AM in reply to: mrkhokhary2k
It is a shame you cannot use certain System Parameters in schedules.  You are looking for "Reference Level", however it is not a schedulable parameter.
You could add a parameter to the ducts and manually enter a value, but you will have to go back, select all ducts on each level and put in the value.  Might not be too bad if you select them all at once in section or elevation.  It still would be nice for it to be done automatically.
Member
malagon03
Message 3 of 6 (756 Views)
01-15-2013 12:41 PM in reply to: asommer
I am required to present a schedule of penetrations for a plumbing job, in which I have to count how many vertical pipes cut through the slab and its respective diameters. Is there any way to create pipe schedules sorted by level or by view template??? is there any way to schedule annotation tags???
I have seen in some forums where it is suggested to use some other attribute of the pipe (like the comments box) to do so. The problem is that some of the pipe runs can be shared by several levels (Vertically). This causes Revit to count this pipe in only one of the slabs that this pipe run cut through. Any other suggestions?? tks!!
New Member
billy.beard
Message 4 of 6 (723 Views)
01-28-2013 09:46 AM in reply to: mrkhokhary2k
A workaround may be to create a generic model for a sleeve and place those and schedule them.  More work to manage but may give you more accurate results in a schedule.
Active Contributor
GlynnisP
Message 5 of 6 (705 Views)
01-31-2013 07:56 AM in reply to: mrkhokhary2k
I'm not sure if this would get you all the data you need, but I had two thoughts:
1.  Use the Revit Interference check (Collaborate Tab) to generate a report between your pipes and the floor slabs.  This would identify how many cut through the slabs but not provide information about the reference level of the slabs.  See screenshot:  http://www.screencast.com/t/ZB3aw7pfyL
You could use the report to make selection sets by ID and then flag a Project or Shared parameter (ThruSlab=yes) if you really wanted to have it in a Revit schedule.
2.  Use Ideate Explorer for Revit to sort the pipes by Reference level.  See screenshot:  http://www.screencast.com/t/lj9wutfHvBh
This would give you the Reference Level data but not identify which are vertical.
Glynnis Patterson
www.ideatebimlink.comwww.ideateexplorer.com
Member
malagon03
Message 6 of 6 (696 Views)
01-31-2013 12:55 PM in reply to: GlynnisP
excellent!!!! tks!!
