When we do ducting the tag leader points to the middle of the duct, does anyone knows how do we change the tag leader pointing to the duct.
Thanks in advance
Gladson
Solved by abulla. Go to Solution.
Thx for your reply, how do I change the attached end to free end, I try to change the family but I cannot change the leader, is there any way I can change/move the leader, I can do without the leader, how do I do with leader.
I can place the leader head any where in the entire duct work, but I cannot place the leader pointing to a duct.
Gladson
Whenever you do anything in Revit, always check your options bar. If you select the tag and check you options bar you will see the option to change the leader type from Free End to Attached End and also a tick box to turn it off.
Hmm I'm not sure I understand the question fully in that case. Take a look at the attached picture, that's where you can change the leader from Attaced to Free End, then just draw a regular 2-point leader.
