Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Labels
3 REPLIES 3
345 Views, 3 Replies
Labels
Are the labels on the electrical devices suppose to be able to rotate so
they are not upside down in the plan
if so how?
if not why not?
3 REPLIES 3
Martin__Schmid
You can try this:
1. Place a wall drawn north-south, and another wall east-west.
2. Place a three-way switch on each side of each wall.. the text on the south side and the east side are 'upside down'.
3. Select the switch, and click edit family.
4. In the switch family, select the Label (the "T"), and click Edit Family.
5. Select Family Category and Parameters... from the Settings menu.
6. Check the Keep text readable option.
7. Load the Symbol Label family into the Lighting Switches family.
8. Load the Lighting Switches back into the Project where you drew the two walls.... now the text on the south and east sides of the walls are 'readable'.
HTH,
Martin Schmid, P.E.
Autodesk Consulting
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
thanks
shouldn't this be the default or do some people like the text upside down
wrote in message
news:5227547@discussion.autodesk.com...
You can try this:
'readable'.
HTH,
Martin Schmid, P.E.
Autodesk Consulting
Yes...believe it or not some people like them to remain aligned with the face of the wall at all times. How many is "some"? Havent' met them all yet *-)
