Revit MEP Forum
Labels with If/Then statement
3 REPLIES 3
dtiemeyer
1951 Views, 3 Replies
Is it possible to put an If/Then statement in a duct label?
I have vertical ducts that sometimes report their size as  48x12 and sometimes 12x48.  I would like to make one label that covers both situations, and uses an If/Then statement to place the larger value first and the smaller value last.
But I can seem to get at the duct properties from within the Family Types dialog of the Label family.
Any thoughts here?
My other CAD is a Cadillac and I like to Revit to the Max!
3 REPLIES 3
CoreyDaun
in reply to: dtiemeyer
Unfortunately, no. Labels cannot be dependent on data; all they are capable of doing is reporting it. And since Duct are System Families, you can't create a Shared Parameter with a formula, either. The best you can do is to create an alternate Tag/Label that manually reports "Width" and "Height" individually, but reversed. Of course, the Tag Type would have to be controlled manually.
tomclements
in reply to: CoreyDaun
Can a shared parameter be created to repeat/ report the value of a system family, Then the shared parameter used in formula's,schedules and tags?
dtiemeyer
in reply to: tomclements
I think that essentially the answer is no. The only reason I say 'essentially' is because a few of the values of several of the system families I looked at can be linked to a Global Parameter (new to v2016r2) which can then be linked to a shared parameter. But if you were to do this, then all the values would be whatever you forced them to be with that global parameter.
