I have a key plan that I need to place on more than one view. Is there a way to have the same floor plan on different sheets? I don't want to have to make duplicate views for each sheet.
Solved by simplexjaevans. Go to Solution.
On my current job I created a jpeg of a plan view & inserted it in the titlesheet family
I generally create a generic annotation of the building by quickly picking the buildings outline then creating the generic annotation. This key plan can then be loaded into the titleblock and if neccessary adding zones to identify parts of the building with associated visibility parameters.
There are three floors with different key plans so would putting it on the title sheet still work? Would I need to do the yes/no parameter with that?
The last one i set up i just used the building outline and included the grid lines because the detail of the rooms was on the blown up plan anyway so if each floor has the same footprint that could work for you. If not you could create a key plan for each floor using the same visibility methodology.
Ok - here is what I tried:
I made a jpeg of the first floor. brought it into the titleblock, scaled it down, and tried some visibility parameters but i can't turn the key plan on and off. I think I am missing a step. I am also afraid the jpeg will look fuzzy. I tried the legend option too and am having trouble with that as well. The plan is a revit project from the architect so I can't put that into a legend view. Any suggestions??
How is the architect handling the Key Plans? Perhaps you can piggy-back off of whatever method they are using (unless, of course, they are creating individual Views for each Key Plan placement).
@meaton224 wrote:I have a key plan that I need to place on more than one view. Is there a way to have the same floor plan on different sheets? I don't want to have to make duplicate views for each sheet.
Believe it or not, but I export the floor plan to CAD (Yes CAD). Bring it into a Generic Annotation family and trace the outside walls with generic annotation lines. Use filled regions as the area indicators and set visibility (yes/no) to the different areas, so I can turn them off and on. Don't forget to delete the CAD files once complete. Save and use.
I then add the generic annotation to the sheet or to a legend view for the sheets.
See attached as an example or you can use it to create your own.
Thank you everyone for responding! I ended up making jpegs and placing them in a legend view and putting them on the sheets.
I appreciate all the ideas!!
Hi, I cannot load into project the key plan created as a generic annotation.
It has parametric properties
Yes, it is in the project browser under the annotations family. There's no error message. It doesn't load in the Sheet...
...I'd just like to add (for other members idea) that it's really better to create the Key via the Generic annotation. Copy pasting to the rest of the sheets should be a breeze, as opposed to creating them in the Legend...
