Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Key Plan Hatching
1 REPLY 1
BRYANBRAUER1832
1316 Views, 1 Reply
Key Plan Hatching
Here is a question that was asked two years ago, without an answer.  I have the same question:
I have a key plan I need to show on multiple sheets. The plan has 3 separate areas. I need to show only one area at a time. How can I accomplish this without placing a region on every sheet.
Preferably I would like to place the key plan with the separate hatches (regions?) in the titleblock family then manipulate the hatche(s) through my sheets.
1 REPLY 1
in reply to: BRYANBRAUER1832
http://www.augi.com/images/uploads/aec_edge/AAE2010Sum-lr.pdf
AEC edge above contains an article on key plans by Paul Aubin.  I have seen another method where you clean up a view and do a drafting view snapshot which forms the background of your key plan then same thing with the yes/no parameters controlling visibility on fill regions.
