Revit MEP
Active Contributor
BRYANBRAUER1832
Message 1 of 2 (258 Views)
Key Plan Hatching
258 Views, 1 Replies
11-16-2012 06:13 PM
Here is a question that was asked two years ago, without an answer.  I have the same question:
I have a key plan I need to show on multiple sheets. The plan has 3 separate areas. I need to show only one area at a time. How can I accomplish this without placing a region on every sheet.
Preferably I would like to place the key plan with the separate hatches (regions?) in the titleblock family then manipulate the hatche(s) through my sheets.
Active Contributor
tim.winnington
Message 2 of 2 (210 Views)
Re: Key Plan Hatching
11-18-2012 03:35 PM in reply to: BRYANBRAUER1832
http://www.augi.com/images/uploads/aec_edge/AAE2010Sum-lr.pdf
AEC edge above contains an article on key plans by Paul Aubin.  I have seen another method where you clean up a view and do a drafting view snapshot which forms the background of your key plan then same thing with the yes/no parameters controlling visibility on fill regions.
