Revit MEP Forum
Is there a way to hide something but keep it tagged?
3 REPLIES 3
revitworkbench
1529 Views, 3 Replies
Is there a way to hide something but keep it tagged? Its an odd request Im sure but I really need this to work. I tried making it invisble (transparancy 100%) but the boardering projection lines still show through. Is there a way to hide the projection lines as well? I tried changing their color to white, but that is uneffective in this applicaiton as well.
3 REPLIES 3
abulla
in reply to: revitworkbench
Use the Linework tool and pick <Invisible Lines>. The tag should stay there.
revitworkbench
in reply to: abulla
This is working, but it seems like I have to double click on every single line that I want invisible. Is there a way to do it in a mass selection? Thanks!
abulla
If you tab-cycle through the selection, you should be able to select the whole object at once.
