Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Is there a reason to still be using the Space Naming Utility?
1 REPLY 1
abulla
447 Views, 1 Reply
Can someone give me a reason why we shouldn't change our Space Tags to read Room name and Number? One of our users asked me why we're still using the space naming utility and I couldn't come up with a very good reason. I can only think if maybe you already have some established schedules, but that would be simple to just change space name to room name. The other reason would be running a heating/cooling load analysis..... but let's be honest, who really uses that?
1 REPLY 1
CoreyDaun
in reply to: abulla
Do you reference Rooms that reside in a Linked Project? You can't really Schedule local elements based upon the Room Names/Numbers in a link - they are still scheduled by the Space's info. Also, there are minor things such as Panel Schedules, which can only reference the Space's Name/Number as the panel's Location parameter.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Rail Community
