I am using Revit MEP 2012 and I created tags for air terminals that read the size of the air terminal and also controls the physical appearance of the air terminal. Basically if I change the tag to read 12"x12" the air terminal changes to this size. In order for it to appear correctly I had to change the project units to inches. Now I am creating a tag for mechanical equipment to work the same way but I want the tag to read in feet not inches. This obviously conflicts but I am wondering if there is any way (I doubt there is just trying my luck) to set the default units to a specific element so this is possible?
If not I'll just accept the mechanical equipment tag to read in inches but if anyone has any ideas please let me know!
Solved by CoreyDaun. Go to Solution.
I don't think you have have different units like that. This is how I accomplished a similar situation:
Project Units: Feet, I want a length to read in Inches
The Parameter "Length" controls the constraints of the family as typical. A Shared Parameter is placed family as an Integer type. The formula for this parameter is =Length / 0' 1". The Tag's label references this Shared Parameter and adds the suffix for the inches symbol.
