Can I add/edit insulation sizes for duct? I would like to put in 1.5" but only have the option for 1 and 2".
Solved by luna.ye. Go to Solution.
Hi dglenn9000,
Click Manage tab - Settings panel - Project Units.
In the “Project Units” dialog, select “HAVE” in the discipline. Click the value in the Format column to change the display value for “Duct Insulation Thickness”. The Format dialog displays. Specify Units, if necessary. For Rounding, select “1 decimal place”, click OK.
Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
When you go to the HVAC tab scroll down to Duct Lining Thickness at the bottom. Click on it & change the Value to nearest 1/2". I also use 1.5" as it shows up better when printing.
If you select the duct you want to add insulation to, the ribboon "Modify | Ducts" tab should show up. Under this tab you should see "Duct Insulation" / Add Insulation. Click Add insulation and a pop up should show up...type in the thickness desired. If you already have insulation added, you can click Edit Insulation and on the Properties tab you can edit the thickness. Hope this helps!
FYI: If you're in a tight ceiling space, I would reccommend showing 3" to account for TDC Joints (unless you have an add-in that already shows your joint connections)
