Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Intereference error
4 REPLIES 4
411 Views, 4 Replies
Intereference error
Hi, i got this problem when i checked error using interference check. There was a report about air terminal which was shown on the attachment. I put this return grille by " place on face" in the 3D view. Did i put it with a right method? Can anyone help me to solve this error?
4 REPLIES 4
abulla
What version of Revit are you running? In 2014, there's an option to mount air terminals on duct. If you're in a previous release, I can see why Revit thinks that would be a clash. Duct-mounted diffusers have to be exaggerated in order to fit a takeoff and a small section of duct, then the diffuser.
in reply to: abulla
I only have floor mounted and ceiling mounted diffuser. And I couldn't find duct mounted to download...
abulla
Check in your library under:
US Imperial\Mechanical\MEP\Air-Side Components\Air Terminals
and look for "Supply Diffuser - Sidewall". That family should work the way you want. If you're in 2014, there's an option when you're placing the diffuser to mount on the duct.
in reply to: abulla
ok, thx a lot!
