Revit MEP
0 Kudos
Post 1 of 5
Intereference error
191 Views, 4 Replies
11-19-2013 01:48 AM
Hi, i got this problem when i checked error using interference check. There was a report about air terminal which was shown on the attachment. I put this return grille by " place on face" in the 3D view. Did i put it with a right method? Can anyone help me to solve this error?
Check in your library under:
US Imperial\Mechanical\MEP\Air-Side Components\Air Terminals
and look for "Supply Diffuser - Sidewall". That family should work the way you want. If you're in 2014, there's an option when you're placing the diffuser to mount on the duct.
61 Kudos
Post 2 of 5
Re: Intereference error
11-19-2013 07:01 AM in reply to: sailaini_415
What version of Revit are you running? In 2014, there's an option to mount air terminals on duct. If you're in a previous release, I can see why Revit thinks that would be a clash. Duct-mounted diffusers have to be exaggerated in order to fit a takeoff and a small section of duct, then the diffuser.
0 Kudos
Post 3 of 5
11-19-2013 06:45 PM in reply to: abulla
I only have floor mounted and ceiling mounted diffuser. And I couldn't find duct mounted to download...
61 Kudos
Post 4 of 5
11-20-2013 07:08 AM in reply to: sailaini_415
0 Kudos
Post 5 of 5
11-20-2013 10:40 PM in reply to: abulla
ok, thx a lot!
