Revit MEP Forum
Insulation
1 REPLY 1
revitworkbench
248 Views, 1 Reply
Insulation
Ok so I have to add insulation based on pipe size and system type. So obviously, modifying in the schedules seems like a surefire way. But I go there and there is no dropdown menu to select the insulations from, you cant type it in and you cant even change the type of an insulation to a pipe that has already been added. Am I missing something? I mean I have more than one insulation loaded, why wont Revit let me change these via the nice drop down menu? Do I maybe have to set my sorting and grouping a specific way to allow this feature to work? thanks!
1 REPLY 1
in reply to: revitworkbench
The drop-downs in a schedule usually indicate and "Instance Parameter"
assigned to a particular family/object. In your case either you need to
assign and instance param to your insulations and pipes, or setup the
schedule to read from the "Type" Params and Props...I don't have RMEP open
at the moment to verify, but I'd start looking here.
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Coordination
mike@VirtualWorldDesigns.com
Building Design Suite Ultimate 2014
Gastonia/Charlotte, N.C. / Jacksonville, Fl.
386-931-6733
"Remembering that you are going to die is the best way I know to avoid the
trap of thinking you have something to lose. You are already naked. There is
no reason not to follow your heart."
--Steve Jobs
