I have this weird issue / Bug in my project, it´s been around for some time now.
see attached pictures.
In the crossing of two gridlines there is 3 different pieces of insulation wich have been added to this location att different times.
I have figured out that it is insulation by creating a filter to hide "insulation type 1". In this case everything dissapears.
Anybody had the same issue or a solution to clear this pieces of insulation away?
//Hampus
I understand your insulation is not responding as expected. Its not clear from your images what the issue is. If you can recreate in a blank file please attach the file to this post. If not, can you copy out the portion from your file and into a new blank file, and assuming the issue is still apparent attach that one. If not I can create an internal FTP for file upload.
Thanks for posting.
