Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Inconsistent wire sizing
2 REPLIES 2
auto99
501 Views, 2 Replies
when I click the wire and then properties, this is what it shows. The wire size should be #12 and not #6.  Where does Revit gets #6?  I cannot change it either, it is grey.
Also, why I cannot change the number of grounds and neutral to 0?  I can change the Hot Conductors, but neutral and ground always come back to 1 even if I change them to 0.
2 REPLIES 2
pteague
in reply to: auto99
I have had the same problem.  Revit doesn't seem to calculate the wire size correctly at all.
MikeDabbas
in reply to: pteague
this because of voltage drop, the circuit is probably long, if you go to your wiring settings, you will notice that Max Voltage Drop for Branch circuit is 2%, if you circuit is long, Revit will do the math for you and upgrade the wire to achieve this voltage drop value...
