why if i try to route a pipe from the pump I cannot select the system of piping? Everztime start with idronic system.
Thank you.
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
Solved by fkleiner. Go to Solution.
Most likely it is because in the family of the pump, the pipe connector properties have it set to be hydronic. Try changing it to global and then it will play nicer if you need it to be something other than hydronic.
I resolved with change system. I opened the property of pump and i moved on an another system.
